Results 1 to 9 of 9
Thread: 3 easy questions!
    DIY Junior Member FrankPlumber's Avatar
    Sep 2007
    Canada
    Default 3 easy questions!
    Hello!
    I have 3 easy questions for you :
    1. The 4 inches stack is often behind the water closet which means the elbow underneath the toilet goes toward the back of the toilet. Can the elbow go in any direction example side, front???
    2. When the 3'' pipe of the toilet runs at the horizontal and you want to make a 90 degree turn, do you have to use two 45 degrees or 1 long 90 degree elbow is legal?
    3. Finally are the use of long elbow and the long Y fittings for all size of pipe is legal?
    Thanks a lot
    Plumber BAPlumber's Avatar
    Jul 2007
    Vashon, Washington
    1. sure
    2,3. you'll have to check your local codes.
    Brent
    Default drain
    1. Definitely, in fact I install more with the stack offset than I do with it behind the toilet. Some plumbers always put it behind the toilet because, "That's the only way they have always done it".
    2. Either way because the two are equivalent.
    3. About the only fittings that have restricted use are sanitary tees and short elbows.
    Jul 2007
    Vashon, Washington
    #2. I've read on another site that there are some juristictions that will not allow a 90 degree fitting except as a closet bend, even though 2 45's are equivalent to a long turn 90. I don't remember those locations, I want to say they were in the northern mid west or canada.
    If FrankPlumber would give his location it might help.
    #3. I've never heard of these being illegal but you might check anyway. I've been wrong before.
    Brent
    Jun 2007
    Licensed Grump
    We use short 90's in 3 places.
    Closet bends, horizontal to vertical & when it's the only fixture or first fixture on a horizontal drain (lav arm, Kitchen drain....etc.)
    Plumber/Gasfitter dubldare's Avatar
    Sep 2005
    MN/ND
    Quote Originally Posted by GrumpyPlumber
    How about vents? Or do you spend the big bucks and use vent 90's, lol.
    --Customers of plumbers: Never be afraid to ask for proof of licensure of the plumber servicing your equipment. A licensed plumber will be proud to show you his personal license.--
    Sep 2007
    Canada
    Default Thanks guy
    Actually I'm from Canada, province of Quebec
    Do you mean you can use short 90's for closet bend when you are horizontal or it' only when you go from horizontal to vertical?
    And for the remaining, if I understood well, you can't use short 90 when you want to do horizontal bent?
    Jun 2007
    Licensed Grump
    Quote Originally Posted by dubldare
    Yeah yeah yeah, ok I fergot one.
    Plumber patrick88's Avatar
    Sep 2007
    Webster Ma.
    You should place a clean out at every change of direction.
    I'm just starting to work with an old friend of mine to bring solar electric and hot water systems, wind turbines, Flex Fuel Boilers, batteries, hydroponic gardening, books, pellet grills and more. Also the parts for DIY installation.
