Blank
I would like to add a bathroom vent to my small, roughly 5x8 upstairs bathroom. Does anyone have an opinion for a configuration? Most of the bathroom vents that I see at Lowe's, Home Depot, etc are ceiling mounted with vent pipe going up (into the attic) and then out the wall. Would it be better to go directly through the wall? I also need a light, but I am not sure if the lights that come with the lighted vents will be bright enough, or if I should use a separate light and vent. I suppose I could go with a wall mounted vent and a wall mounted light...... What examples I have seen seem to work, so I suppose that nearly any configuration would suffice, but I was wondering if anyone knew if one way (through the ceiling) or the other (through the wall) was better for venting. Thanks.
