Well, you'll get lots of opinions...here's mine. You need a vapor barrier on the ground of the crawlspace. You didn't have a problem since it is well ventilated. WHen you add insulation, you will be stopping that airflow. I'd consider a spray-in foam for insulation in the walls. This would also add a vapor barrier if it was a closed cell foam.
