Results 1 to 15 of 19
Thread: Champion Accelerator Flush Valve
Hybrid View
    DIY Junior Member RBrown's Avatar
    West Virginia
    Default Champion Accelerator Flush Valve
    My sister's Champion toilet is having a flushing problem. American Standard sent her parts including a replacement for the "flush tower". It's call the Accelerator Flush Valve, and I hope it cures her problem. The new valve is similar to a flapper, except that it pulls straight up instead of being hinged. They also sent her a new tank gasket and a special plastic wrench.
    The AS website now touts the Accelerator Flush Valve, and the old flush tower is gone.
    Apr 2005
    Yes........and the trip lever doesn't work quite right unless the tank lid is pulled a little forward to where it lodges in a normal position.
    I switched one out about a week ago
    It's very hard to flush.....takes some strength to push that trip lever down. The second picture denotes that trip lever hanging almost
    vertical when the tank lid is off.
    Now there's almost 4" of unused water in the bottom of that tank as well.
    Default Bad design
    To be honest with you thats about the worst design ive come across in a toilet! I just modified one about 3 months ago. I would at the least replace the bent up trip lever with a new one, attatch a second one with a degreed bend on it by using #10 ss small bolts so it extends over the release.
    This will at least make it easier to flush.
    Apr 2005
    Quote Originally Posted by tonykarns
    It seemed to me that it was the actual flush valve that was making it hard to flush....not the setup of the trip lever.
    I checked this by manually pulling the flush valve assembly up by hand.
    Lots of water/head holding that assembly down flat. I personally do not like the design at all.
    West Virginia
    Default Accelerator Flush Valve Installed
    Rugged,
    Sis got her toilet fixed today. Her plumber installed the AS Accelerator flush valve and it works fine. It's not too hard to push the trip lever, just a bit firmer than the AS Flush Tower. With the tank lid off, the trip lever is in its normal horizontal position, and the installation is neat as a pin. Her installation looks much neater than the pics you posted showing the arm all bent. She is a very happy girl.
    DIY Member micp879's Avatar
    Jul 2007
    Martinez, CA
    Thanks for posting the results. I will be replacing the flush tower on my parents Champion toilet with the new accelerator valve in the near future, and I was getting a bit concerned, based on the posts in this thread. I was going to comment that in the above picture, the trip lever and trip lever arm look nothing like the trip lever in my parents Champion. The lever in theirs is longer and appears like it should be a much better match. It makes me wonder if a different trip lever would maybe benefit the toilet in the picture.
    DIY Junior Member tntrvlngrl's Avatar
    Feb 2013
    Tennessee
    Default Flush valve
    I've had this flush valve for about 4 or 5 years and I love it; it works perfectly!
    Quote Originally Posted by Dunbar Plumbing View Post
    West Virginia
    When you finished changing it out, did it flush ok? Does the trip lever point up all the time? I hope it doesn't, sis won't be too happy.
    Apr 2005
    Quote Originally Posted by RBrown
    Yes........flushes okay but it's very hard to push that trip lever down to flush.
    The trip lever sits in a "normal" position when the tank lid is on...not off.
    I told the customer that if they have to have a plumber work on that toilet again......replace it completely and get away from that flawed design.
