Fernco makes a rubber insert that replaces a lead poured joint.
I sometimes use a drill bit and drill out a bit of the old lead, pry the rest out with a screwdriver and pull the oakum out.
A little bit of liquid soap helps the pipe to slide in. I also take a knife and taper the end.
2" ABS pipe into a cast iron hub fitting using a inside Fernco.
