ultraman99
- Messages
- 5
- Reaction score
- 0
- Points
- 0
recently i had to raise the solenoid valves for my backyard due to drainage issues in the box. after i raised the valve set, i tested the sprinkler system. water was flowing out of the all sprinkler heads, but not enough water pressure to make them pop up. i looked around for spots in the yard for pooling, but no luck. my front yard and back yard share the main line and the front yard sprinkler system has no problems (front and back yard are 2 separate systems, just sharing the main water supply line).
i diverted the water supply to the solenoids to take a look at the water flow out of the line, and didn't seem like enough water was coming out, lacking volume/pressure.
i'm at a loss...what should i check for next?
thanks in advance!
thanks in advance!
