My basement bathroom toilet is almost ready to install. My closet bend is just a 1/8 inch above the cement basement floor. I have a flange that fits on the outside of the closet bend. I put a cardboard sleeve on the closet bend when I did the cement and i can dig it out now and the flange should fit over it.
So I assume I would install my linolium floor first and then install the flange?
My worry is I assume I need to glue the flange to the closet bend (ABS glue) and then use cement screws to tie it to the basement floor through the screw holes in the flange.
BUT......What if in 5 years the flange breaks...how would I replace it without needing to tear up the concrete and replace the bend? Does Anyone just set the flange over the closet bend and screw it to the cement floor and NOT glue it? Like maybe just silcone caulk it so that if you ever needed to remove the flange I could.
I just think a broken flange glued to a concrete embedded closet bend would be a nightmare to fix.
Am I to woried about nothing?
Thanks!!!!
Thanks!!!!
