sounds like you have an s trap for your laundry room sink, which has no vent, and are not allowed by code in most if not all areas.
can you run a vent up thru a wall into your attic to tie in with an existing vent, or to run it out your roof? an AAV (air admittance valve) may be ok, but I don't know anything about those, someone else should have more info on if that's a good option for you.
