You're correct.
When I do a kitchen/bath remodel where the existing drain is directly below a new window, I prefer to simply drop a new drain off to the side with a horizontal drain cut in from a T-wye & vent running straight up in the same bay.
The horizontal drain can then run out at an angle to avoid cutting into studs or window jacks.
Window jacks are considered load bearing, drilling through them isn't allowed in my state, it could cause a bow in the exterior wall.
