Queston on replacing bathtub drum trap - questionable existing?
Mckeand13
Engineer
Orono, MN
www.project-one.us
I'm interested in replacing the drum trap on my bathtub with a PVC trap. Was there a point in drum traps? I replaced one at my last house as well because it was all corroded and closed up.
Anyway, take a look at the pictures. The tub drain comes down, elbows, and then goes into a brass "tee" with threads on each side. The one coming down just looks like it's got a piece of brass pipe shoved in there and sealed. It just doesn't look right.
Shouldn't some type of fitting come off the bottom of the tee, transition to pvc, and then continue on to the trap?
Cwhyu2
Consultant
Cincinnati OH
Drum traps were used to catch stuff and cleaned out every now and then.
By all means replace it with a P-trap.
GrumpyPlumber
Licensed Grump
Licensed Grump
The trip waste looks fairly new, the standpipe looks like galvy..get ridda that, it'll rust closed before too long.
You should be able to loosen the desanco nut (slip nut) at the top of the standpipe, then cut the copper and take it all out.
Replacing with a p-trap should be a snap, just use a mission clamp from the copper to PVC.
drain
There is supposed to be a "trap connector fitting", (it goes by many different names depending on which part of the country you live in), on the galvanized pipe and then the tubing slipped into it. When that was installed, (I never used green drum traps mine were always black), the did not have PVC and even if they did, inspectors would not have allowed switching from material to material for no good reason.
