I have a 1/2 HP Myers RC5 pump on top of a 20 gallon pressure tank.
Recently I've noticed that the water pressure in the house would just stop and then a few seconds later it would be back strong.
I observed in the well house that when the water is being used the pressure slowly drops to 20 the pump then begins to hum and will sometimes kick on a few seconds later and pumps up to 40.
I can see the fan blades on the motor start to turn when the humming starts its like the fan will move about 2 inches and stop then another 2 inches and stop until the pump either kicks on and starts pumping or it gets hot and shuts down for a few minutes.
I searched the forum and found out about capacitors. I took one in to be tested and he said it was good and wondered if there was another capacitor
somewhere on the motor. The capacitor that I found was in a plastic case on the outside of the motor. Does it sound like a capacitor or am
I way off?
Oh I ment to say that when the pump starts to hum...the pressure which was dropping slowly SUDDENLY drops to ZERO.
I way off?
