View Poll Results: Which is best? "Americast" or "Cast Iron" tubs
Voters
9. You may not vote on this poll
  • Cast Iron Tubs
    9 100.00%
  • Americast Tubs
    0 0%
Results 1 to 5 of 5
Thread: Americast or cast iron tub?
    Electrician sparks98's Avatar
    Feb 2005
    Philadelphia, Pa
    Default Americast or cast iron tub?
    Is Americast equally as strong as a cast iron tub (like they claim)? Do Americast tubs need mortar under the bottom to give them the cast feel? I'm putting in tile on the walls and above the tub, so I DO NOT want to EVER have to rip all that tile out because of a CHEAP tub.
    Default tub
    It is adeqately strong, but whether it is as strong as cast iron is questionable. You do not have to "shore" it up.
    Feb 2005
    Talking americast is junk
    all americast is , basically a cheap steel tub with an epoxy resin base .'
    I dont like them, they have a tendency to lose their luster after only a few years. the americast kitchen sinks do wear out fast.
    also if you drop something in the unit, you can chip the tub....
    even cast iron will chip... but its more durable and it looks good after a long while.
    acutally, I feel that the Sterling bath fixtures are as good as any for durability.
    If you put concrete under one it feels like cast iron and it wont ever chip.
    Short of takeing a claw hammer to it, it is literally indestructable.
    DIY Junior Member raygunclan's Avatar
    Mar 2005
    Florida
    we have an americast sink that has rusted all around the edge. this would maybe be acceptable if it were, oh, say, 100 years old!
    sincerely,
    girl who removes rust with white paint
    Default vote
    That is a matter of individual preference. I will use either depending on the circumstances. I do not consider one necessarily "better" than the other, although for my own use, I would use cast iron.
