Thread: Replacement window balancer?
    Engineer chassis's Avatar
    Sep 2005
    SE Pennsylvania
    Default Replacement window balancer?
    I have single pane double hung windows, they are original from when the house was built in 1950. The balancers are steel coil springs about 18-24 inches long, and are accessible without tearing the window jamb apart.
    I have a few of these springs that are broken, would like to replace them. As far as I can tell, the windows are "Curtis" brand. Couldn't find anything by searching on the internet. Can anyone please recommend a source where I can order the replacement balancer springs? Thanks.
    Plumber jimbo's Avatar
    I have never seen a balance that was not replaceable. I can't picture yours from the description. But the fact that you know it is a steel coil means you have some idea what it is. Almost always the balance can be removed by screws, if it is a steel wire wrapped in a spring coil,....or the springs are accessible by removing an access panel. You might have to look closely as the screws may be heavily painted over.
    Some pictures would help.
    Jul 2005
    Marin Co. Ca.
    I have an acct. with C L R ,GO TO THERE ON LINE CATALOG
    They will sell to you. They supply all the glass shops
