Page 1 of 4 1234 LastLast
Results 1 to 15 of 57
Thread: Heated pet bowl question
    Thumbs down Heated pet bowl question
    I bought a heated pet bowl for indoor use, but it heats the water way too hot since it was intended for outdoor cold climate use. Electrical info on the pet bowl is 120V, 60Hz, 75W. It doesn't have any controls.
    I want to add a control to drop the heat level. A friend said I should not use an ordinary dimmer but use a unit rated for motors, so I bought what was available at my local hardware. It is a Speed Control, 5A/120VAC, for a ceiling fan.
    After I got home, opened it and read the instructions, it says it is for use only with split capacitor or shaded pole motors used in ceiling fans and should not be used to control receptacles, etc.
    I had intended to install the Speed Control into a separate box (but not mounted on or in the wall) with a line to be plugged into a nearby wall receptacle. The box would contain the Speed Control and an outgoing receptacle to plug the heated bowl into. The heated bowl uses a GFCI plug.
    Based on the manufacturer's instructions to not use the Speed Control to control a receptacle and to use it only with certain types of motors, is what I propose dangerous? If so, what is the alternative?
    George
    Jun 2007
    North Carolina
    Quote Originally Posted by Majus
    Yes
    George
    Why would you want to serve your pet hot water?
    Are you making coffee?
    The water will become room temperture in a matter of a few minutes so why heat it?
    What is going on here with this pet?
    Smile
    Quote Originally Posted by jwelectric
    Yes
    I don't want to serve her _hot_ water, I want to serve slightly warm water since she prefers that. I keep my house quite cold and after the water bowl has been out for a while the water gets too cold and she won't drink it.
    Coffee? No, she doesn't care for it.
    The water will _not_ go to room temperature as the bowl supplies a constant heat source.
    What is going on with my pet? She's got preferences, as does everyone, and I'm just trying to make her happy.
    All that being said, since you say what I propose is dangerous, what is my alternative?
    George
    DIY Senior Member BrianJohn's Avatar
    Jun 2007
    VA
    A NEW PET might be the answer.
    Jun 2007
    North Carolina
    George
    To control the temperature of the water you will need to have a thermostat that reads the temperature of the water and regulates the current flow to the heaters based on the temp of the water.
    To try and control the receptacle or the heater in the bowl from a remote location such as a switch box would require a probe to be inserted into the water.
    Without something to let the heater know when to come on and off based on the temperature of the water there is no way to control the heat of the water.
    As a side note; if your pet desires hot water over cold water it might be a good idea to have her checked by a vet.
    As a pet owner of many different types of pets and animals I can say with experience all of the animals I own will always come to fresh cold water.
    Attached is a couple of my pets here is a couple of the dogs and let's not forget the cat. If you would like I will post some pictures of the birds and horses.
    Thanks, jwelectric; those are the answers I needed.
    I opened the bottom of the pet bowl to see what was inside. Nothing but wires in a pattern attached to a piece of foil attached to the bottom of the stainless steel bowl with a component about .75 long and .25 across inside the heatshrink tubing which apparently controls the heat. The heat seems to be constant.
    I think I'll just abandon this idea; it doesn't seem to be practical. The heated bowl will go on **** sometime and the Speed Control will go back to the hardware store.
    As for your comment about the vet, she's an indoor cat and does see the vet if she needs to, but at least once a year for a physical and shots. Her drinking behavior has been constant for years so it's nothing new, and I have spoken with the vet about it in the past.
    I just thought I had a simple solution -- not the first time. Ha!
    Thanks for the pics -- beautiful animals, all, especially the cat and the Shepherd.
    Thanks again, and have a great weekend!
    George
    I've got it!
    Install a large magnifying glass just above the pet bowl, so it catches the incoming light and heats the water.
    Smile
    Quote Originally Posted by Verdeboy
    I've got it!
    Uh, I think that's old technology; solar panels would be the way to go.
    Thanks for the suggestion, though.
    George
    Engineer Furd's Avatar
    Jul 2007
    Wet side of Washington State
    Two of my kitties.
    Plumber jimbo's Avatar
    The reason not to connect any kind of control to feed a receptacle, is that many devices which may inadvertently be plugged in to that receptacle will not work, may be damaged, and in fact could be dangerous.....if run through any kind of speed control or dimmer. You know exactly what you intend to do, but instructions and codes must protect assuming that anyone in your family, a visitor, a tradesman working in your house, or some subsequent owner, will have no idea what is going on there.
    Best bet is to make the bowl heater thing a stand alone, self contained in a box, and plugged into a standard outlet.
    It's your business, but I sort of side with the others who suggest you rethink this whole pet priority situation!!!
    Smile
    Quote Originally Posted by jimbo
    That was my idea, to make a separate, stand-alone box not on or in a wall which would have only the Speed Control and one outlet for the water bowl and clearly labelled as such. This box would, of course, have to be plugged into a power source which would be a wall receptacle.
    In my layman's eyes at least, it seemed that it would work because the motor control would cut down on the power delivered to the bowl thus dropping the heat output.
    Since the box itself would not be physically connected to the house, when I move it would leave with me.
    George
    DIY Senior Member CHH's Avatar
    May 2007
    Denver, CO
    Why not just use an aquarium heater?
    Quote Originally Posted by CHH
    I've never seen one. How do they work? Do they go into the water?
    George
    May 2007
    Denver, CO
    I'm sure aquarium heaters come in many shapes and sizes. The ones I'm familar with are partially submerged and tend to be fragile. For a cat they should be fine. For a dog, no way.
    Now go to a pet store or use google to check'em out.
    In the Trades Bob NH's Avatar
    Oct 2005
    New Hampshire
    If you have a metal pan like the ones with space under them you could set it over a small light bulb like a christmas tree light or a night light. It would keep the water a few degrees above room temperature.
    I would put the pan on a peice of ceramic tile that is raised slightly off the floor. Increase the insulation to raise the temperature of the water.
