Our 70 feet 3/4 " water main has had three leaks in a year and seems to have been patched up to begin with.
I am thinking of renting a trencher and replacing it myself to avoid the big bill. I am handy, learn fast, but have no plumbing experiece. Am I biting more than I can chew on this one?
A couple of Questions: The contractor that came out to do an estimate suggested I use Pex pipe. What are the pros/cons of pex vs. copper? What material do you suggest?
The old main does not run in a straight line. It makes an L for no apparent reason. Do you suggest to follow the path and depth of the old line or attempt the straight (shorter, no corners) ?
I know ther's flexible copper. How tight a curve can I make with it?
Finally, could I just go ahead an do this, or does it require inspection?
monemi
monemi
