Results 1 to 9 of 9
Thread: Bacement cleanout trap has a small hole
    Default Bacement cleanout trap has a small hole
    Hello all--I have a cast iron --Trap that runs along the basement wall--Its U shapped with two 4 inch cleanouts plugs on it--My problem is--I noticed a small leak last night on my basement floor--and found that the pipe has a small hole right at the U therest of the pipe is fine--My question is--Can i go to ********* and get some type of a patch kit or some kind of a fiberglass repair-such as the ones they use on OIL TANKS that leak.. Right now i have Silicone adhesive over the small hole and its working 100% no problems--I dont trust that tho--I want a better patch! Why the hole is there is another question--The pipe is old--and doesnt have any other areas that need fixing--I think when i added Acid to the pool through the pipe--It did something.. Thanks for any help!! Have a great day!! MARK
    Plumber BAPlumber's Avatar
    Jul 2007
    Vashon, Washington
    post some pictures if you can.
    Brent
    Consultant cwhyu2's Avatar
    Aug 2007
    Cincinnati OH
    Try jb weld epoxy.
    Plumber Cass's Avatar
    Nov 2005
    Sounds like a whole house trap...how old is your home.
    Default The house is about 65 Yrs old
    I know i can change the trap assy--But i'm also sure i can seal it--Hell--They seal Fuel oil tanks 275 gal jobs--With fiberglass sealer--I've seen it--So this trap should be a snap to seal.. I sanded the area--Its all clean now ready to seal.. I was also told by a few other about JB Weld.. Thanks so much for getting back to me.... All of you!! Have a good night! MARK
    Default hole
    Cast iron pipes do not have "small" holes. The small hole is usually just the tip of a larger pit on the inside. If you tap around the small hole you should have a large hole in short order.
    General Contractor Carpenter toolaholic's Avatar
    Jul 2005
    Marin Co. Ca.
    Thumbs up Cheap Enough
    Try the J B Maybe You'll get lucky for 20 years!
    Feb 2005
    Talking USE DUCT TAPE or Electrical tape
    The silicone seal that you put on the trap will probably
    be good for 20 years....perhaps add another layer or two
    and its good for an extra ten.....
    Now if you really want to make the next plumber mad...
    take a roll of electrical tape or duct tape and roll about
    30 feet worth of it onto that trap ell....over the silicone....
    it is hell to get off
    but is seems to be what I run into all the time under kitchen sinks.....
    and it usually works fine untill everything on both sides of the patch
    finally rots away....
    god created all men,
    Default traps
    That or a half inch of silicone puttied over each slip nut connection.
