Yar02169
First of all, this site is an awesome source of information, and I thank all that provide others with helpful information.
I have a shallow well that has been in development for some 6 years now. I'm finally to the point where I have some good flow (10 gpm), but I still have some tweaking to do.
One issue that I have is that I do get some sand into the system, not a lot, but enough to occasionally keep the solenoid valve(s) open. I bought a sediment filter that I plan on installing, but to do so I will have to cut pipe. My plan is to install the filter with Unions so that when everything is up and running, I may be able to remove the filter and replace it with straight pipe that has no restriction. Unfortunately, the one Union at the pump seems to be discontinued because I cannot buy a Union that will fit (screw on) my existing one. I will need to re-build the plumbing between the pump discharge - filter - system. I know that I need a pressure gauge, but is my small (2 gallon?) air-tank necessary? The well is only used for irrigation, and I have no idea why an air tank is needed. 99% of the time it will be used for the sprinkler system, with an occasional hose use. Does the tank act as a pressure cushion when the system shuts off, eliminating stress to the pipe joints?
I will use the tank if it's needed, but it will look much nicer without it.
Thanks.
Thanks.
