the more you can get that swanstone to fit down into and touch the actual tub ,
the better off it will look and be....but you will be wise to put a good healthy bead of Silicone along that area between the tub and the walls.
it depends on how old your home is and how crorked your walls are....
swanstone does make trim that will match the walls you are putting up and it will hide all gaps or imperfectioins in the angles .. it is just like putting up CORIAN...
they both need trim in certian areas cause you cant make it exactly perfect
figure on useing lots of clear 100% SILICONE and it willwork out good...
