Thread: Lennox, Tran Vs. Ruud Ac
    Talking Lennox, Tran Vs. Ruud Ac
    I would to know how Lennox and Tran compare with RUUD AC?
    PRO and CON about all three AC in the 13 SEER.
    Which one uses the most kHw and the one that uses the less kHw? Yes I know we are talking about the same seer.
    If the sizes are identical and the SEER is the same, their energy use should be nearly identical. The differences might come in with the air handler and the choice of fan speeds and the timing of how long it runs the fan, which is a function of the thermostat and air handler control circuits.
    Compare the warranties and features.
    Quote Originally Posted by jadnashua
    Yes that would be one of the BIGGEST things to check WARRANTIES and FEATURES of the three, you maybe surprizzed at them.
    Also how loud they run.
