Results 1 to 2 of 2
Thread: Pex or CPVC
    Question Pex or CPVC
    Not sure if I should post this here or in the remodel forum, so here goes.
    I live in a townhouse that was built in the mid 80's. Existing plumbing lines are Quest. This has been nothing but a problem since I bought the place. I have had nothing but water leak after water leak.
    I want to replace the plumbing, and was looking into either PEX or CPVC. I am trying to limit the total amount of wall damage that I have to do, so PEX is my leaning at this time. I figure that for my longest runs along each side wall I could use the existing line as a "pull line" for the new, and stub out the ends using the copper adapters.
    Should I use separate home runs for the supply lines, or copy what the existing lines look like now. (a standard installation with 1 major shut off valve)
    Looking for a few suggestions. This will be a fast moving project when I get started.
    Plumber Plumber2000's Avatar
    Jan 2005
    Eugene, Oregon
    I'd copy what you have, there are pex angle stops, saves time when you use them, they crimp on just like the fitting.
    Plumber for 20+years
