Rick.a
I have a dug well at my summer camp and it's a pain to pull the jet pump when winterizing it each fall, mainly cause bugs and junk fall into the drop pipe hole and each Spring I have bacteria in the water and have to disinfect the system.
I am thinking about putting in a submersible and sealing the whole thing tight. Do you think I can pull this off and not have anything freeze? Here is the setup:
Well is about 30" diameter concrete casing (about 20 ft from the lake and about 8 feet uphill). Water level is at 9 ft from top but bottom of well is only 18 inches below that. We have never run out of water...yet. It must fill fast since the lake is so close. I will be rebuilding the pump house around/over the well since the wooden one was crappy. I will build it of concrete block and seal it real good, but it will NOT be freeze proof. I plan to then put a lighter cover over the well (but it will be sealed) since the current concrete cap will be difficult to remove with a pump house over the well.
My questions
1. Is 18 inches enough for a submersible? Digging it deeper would be difficult. Suggestions?
2. Is there a way to water to drain back into the well so the water level in the drop pipe will go down below the freeze level- without opening it up? Freeze level here in Massachusetts is about 4 feet, but probably lower in the airspace of the wide well. It is steeply uphill to the house from the well.
Pic is current well with pumphouse removed and the current jet pump on top.
thanks,
My questions
thanks,
