Page 1 of 2 12 LastLast
Results 1 to 15 of 27
Thread: Hot water issues
    Default Hot water issues
    This may not seem strange to you guys but to me it is. I cannot get hot water in my kitchen sink unless I first turn on the hot water in my shower. I have plenty of water pressure on the hot water side. I have flushed the water heater just to cover that. Any ideas?
    Plumber jimbo's Avatar
    Is it that you get NO water at all, or you get water but it is not hot? If the latter, does it eventually get hot if you let it run a long time?
    Consultant cwhyu2's Avatar
    Aug 2007
    Cincinnati OH
    Several things you could look for .check shut off under k/s.If it off and
    have single valve faucet it might byassing hot to cold and coming out
    the cold side of the k/s faucet.More info would help.
    Default Re:
    I have plenty of water pressure it just doesn't get hot unless I turn on the water in the shower first.
    I have double valve faucet with two seperate water supplies under the sink.
    one hot and one cold.
    Aug 2007
    Cincinnati OH
    Is the shower valve single?
    one thing, i have an expansion tank in line before the suply line gets to the water heater. It is warm and when I turn on the hot water I can put my hand on it and it doesn't feel anything is leaving it and also it doesn't cool off any. could it be stopped up and could that be the culprit?
    the shower valve also is double.
    Aug 2007
    Cincinnati OH
    How old is the w/h?
    Jun 2007
    Licensed Grump
    One VERY good question...you say you get no hot water at the KS faucet...are you getting ANY water on the hot side when the shower is off?
    about a yr old give or take a little bit. It's a State Select 40 gal.
    Aug 2007
    Cincinnati OH
    Ok I thougt abuot long hard .You may have a broken off dip tube inside
    the w/h.It can cause cold to become warm.look up w/h and
    expansion tanks.This may help better under stand how they work.
    yes I get water with good pressure on the hot side of the k/s when the shower is not on. It's like I have to prime it by turning the hot water on in the shower to make it get hot in the sink. Then it gets hot. I turn the shower off the water in the sink cools to luke-warm.
    I will check although, the shower water stays hot, way longer than it has to. it is only in the kitchen sink that it either isn't getting hot or isn't staying hot without the hot side of the shower turned on.
    Jun 2007
    Licensed Grump
    This sound slike you might have trouble at the shower valve.."path of least resistance" type trouble.
    If the shower valve is allowing cold to get by into the hot line and it's less distance, fewer offests or larger pipe..(a few other variables) the cold is possibley cross feeding into the hot side through the shower...when you open the shower it closes the cross connection...you might start by letting us know what type shopwer valve it is.
    If it has a balancing cartridge, that could be the trouble...cartridge might be ceased...partially of fully.
