spebby
- Messages
- 28
- Reaction score
- 0
- Points
- 0
I removed the badly cracked concrete slab of my carport with the intention of building an attached garage. My water well, pressure tank and water softner was in the carport. I replace the copper line from the well to the house and uncovered a 2" cast iron sewer pipe in the process. I decided to add a drain for the water softner by tying into this cast iron pipe. In the process of digging around the cast iron pipe to find a suitable place to make the tie-in I ran into a connection where the 2" cast iron pipe along with a 3/4" copper line were connected to 4" orangeburg" pipe. The connection was encased in concrete. I decided to remove this section and cut through the orangeburg, gently busted up the concrete and used a fernco to attach the cast iron pipe to 2" pvc then using a 2" to 4" bushing increased the size to 4" pvc. However the orangeburg was not round and I could not get a fernco to seal that connection. The orangeburg headed under the concrete slab of the back porch. I probed and found where the orangeburg exited the slab on the other side, and found another concrete encased joint where the 4" orangeburg was connected to a 3" cast iron el. I piped around the slab with 4" pvc making sure I had proper slope, and added a clean out. The 3" cast iron el was connected (again encased in concrete) at the other end to some type of 4" plastic pipe that I have never seen. My question: This 4" plastic pipe is a dark gray in color and has thin walls. I used a fernco to connect the sch 40 4" pvc to this pipe. It appears to be in good shape. I was tired of digging in 100 degree heat and the plastic pipe headed under a deck. Any guesses to the type pipe? Should I remove the deck and replace this line with sch 40 PVC. This sewer line drains the washing machine, kitchen sink, dishwasher and water softner and heads to my septic tank about 100 ft away. (The drains for the bathrooms are at the other end of the house)
