Rando Tyler
- Messages
- 1
- Reaction score
- 0
- Points
- 0
A buddy of mine has a shallow well 1 hp jet pump. He had the motor bearings replaced then he changed out the pressure switch. Now the problem is when it is energized it will run for about 15 seconds and then the overload switch( I think) opens.. after it sits for a couple of minutes I can hear the switch close and then when I energize it it will run once again for the 15 seconds. I metered the amp draw on both lines( it is 240 volt application) and I get a reading of 33 amps per line until it shuts down. Here is my question. Could the centri. switch not be opening and is it possible it is letting the cap surge continue until it overloads? Any thoughts from anyone will be helpful. If I have left any needed info. out please advise me . Oh by the way I have the pressure switch by passed so it is not the pressure switch.
