Geniescience
Homeowner
a friend showed me his low flow last night. I was amazed how almost NO water flowed in the lav, after the toilet was flushed. It is worse on one side of the house. It was always bad but it got so bad in the last two years that now they take theirs showers in the YMCA gym instead of at home...
Possible causes? Anything to be done? Anything that might improve the pipes' flow, instead of breaking open walls and replacing pipe?
He got the house five years ago; it was built in 1950, the visible pipes in the basement are 3/4" copper entry from the city, a 3/4" copper ballcock valve, a reducer and 1/2" copper from there. There will be a number of elbows in the walls too. Distance run is 50 feet to the two bathrooms on opposite sides of the house. The copper looks new to me, not old. Under the kitchen sink are new looking braided flex supply, and new PVC drains properly designed, and so new they still have bar code labels on them from the store. He has no other information about what might have been done before he got there.
I told him that he has two problems combined: one is that a 1/2" copper pipe (30 feet away from the kitchen and 50 feet from the bathrooms) is barely large enough for a house with two full bathrooms and a fully equipped kitchen.
The other problem is something else making the situation worse, but I have no idea what it is. Something blocking flow, down at the first Tee?
The only change he has done is to install a new shower valve. That side of the house is where the problem seems worse, the flow is lowest. He didn't want to measure flow with a stopwatch and containers, but I might just insist.
David
David
