Page 1 of 2 12 LastLast
Results 1 to 15 of 29
Thread: Flux ?
    Default Flux ?
    Hey guys,
    I was helping my buddy with a valve install last night and I noticed that he was using a different kind of flux.
    He was using the Oatey with the green label. It is called No 95 Tinning Flux. I always use the one in the red container, I believe called the No 5.
    What is the difference between these two?
    Tom
    Plumber Cass's Avatar
    The #95 is a pre tinning flux. As it heats it leaves a lite coating of tin on the fitting and pipe. This helps with the capilary action of the solder. I use it.
    Should I start using it?
    Are there any down sides to it?
    Tom
    Dec 2006
    Grumpy will mock you... but I think that's about it.
    LOL! He mocks everyone so what's new. He usually has a good point though.
    So what is the deal. Should I switch?
    Tom
    Dec 2006
    Apparently the self-tinning is easier, and some of the pro's use it (Rugged, for one)
    Not sure what (if any) disadvantages are.
    I only learned about it recently, here: check out the "how to solder" thread...
    My guess is that it probably costs a little more and may be harder to find at a big box store.
    I use #95 part of the time. I got it by accident or something and I haven’t run out yet so I still use it. I feel that flux is flux (as long as it is made for plumbing.
    One who lurks Basement_Lurker's Avatar
    Jun 2007
    Victoria, BC
    The big deal of Oatey 95 flux is that it won't turn the pipe green afterwards, while the regular fluxes will if they are not cleaned off sufficiently. The #95 flux costs me about 5x as much as the regular stuff, so I just use it on exposed piping, and use the regular stuff on piping that will be enclosed. The product description claims that the #95 flux will never burn away (unlike the #5 flux), which is a definite advantage, especially for soldering novices.
    Sep 2006
    Phoenix, AZ
    I use Coppermate flux and silvabrite solder and never have had a problem (that was not my own fault - LOL).
    Jun 2007
    Licensed Grump
    Quote Originally Posted by frenchie
    I'd never!
    Well...maybe
    Quote Originally Posted by statjunk
    Tom
    Tinning flux is fer wimps...where can I get some?
    Seriously I just wonder if it isn't something intended to appeal to those who don't have alot of experience with soldering...though admittedly if Rugged uses it..I might try it...just maybe...shhh..I didn't say that.
    Quote Originally Posted by markts30
    I SWEAR by Silvabrite...it's the ONLY solder I'll use.
    Jun 2007
    Licensed Grump
    Quote Originally Posted by got_nailed
    Give Nokorode a try and get back to me.
    In the Trades kordts's Avatar
    Oct 2005
    exurban Chicago
    I use No-Korrode and whatever solder I buy on ****. If you sand the pipe, use a fitting brush on the hubs and stir the flux, you won't have a leak except once in a blue moon.
    Plumber BAPlumber's Avatar
    Jul 2007
    Vashon, Washington
    I've used Oatey and NoKorode. I think Everflux is hands down the winner of the water solubles. Laco was always good.
    Brent
    Ok I got a small tub of Nokorode and I’ll use it this weekend.
    I do think this is going to come down to 50 of one and 50 of another. Everyone will say that one is better than another. The reason that I could give a rats as about what type of flux I get is my g/f dose my ordering and keeps up with my stock. What I get is what I get. I have used a few that I hope I never use again and I told her I didn’t like them.
    But as it has been said if you prep the pipe right then it should work just fine. I will say that the final look of the job can be affected somewhat by the flux until you get used to it. For me if I pick up some that I’m not used to my first 3 or 4 don’t always look the greatest but after that they look fine.
    I’ll let you know how I like the Nokorode next week.
