mulman
Hi,
I purchased a Fleck 5600SE based 24K grain water softener with 0.75 cu ft SST-60 resin over the internet. I installed the system and its softening great. Now, how to correctly program the regeneration?
I guess the SST-60 is supposed to use less salt and less water to regen. We have a well and septic and I'd rather not use more water or salt than I need to. Currently the system is set at: 1-10 2-60 3-10 4-12 (10 minute rinse, 60 minute brine rinse, 10 minute post brine wash and 12 minute brine tank refill). I called the vendor for help programming the unit and he said that for the SST-60, just change the brine tank refill to 10 minutes. I'm not convinced! He said that in step two, the unit draws brine for about 10 minutes, then just cycles it through the resin. So, by changing the setting in step four, I am effectively changing the brine draw setting in step two?
Can someone clearify how this works and how to program the valve correctly?
Thanks.
Mike
Thanks.
Mike
