Results 1 to 6 of 6
Thread: Sweating tip
    Default Sweating tip
    Only sharing this because I just battled it!
    Don't make your last sweat the bottom elbow. That's the one that fills with water from the pipes you sweated above and angled down slightly.
    DIY Senior Member CHH's Avatar
    May 2007
    Denver, CO
    Agreed, always start low and work your way up. That way the knees and back don't hurt so much when finished. Of course they still hurt but maybe I don't notice it so much when I'm focused on the next joint.
    By the same token, always sweat from left to right unless you're Rugged and then I'm sure he sweats from right to left.
    left to right? right to left?
    Hey, let's keep the politics out of plumbing!!!
    Jun 2007
    Licensed Grump
    Quote Originally Posted by CHH
    Naah, he simply goes into a transcendental trance-like state and the pipe sweats itself..."Be one with the pipe....be one with the pipe Wwwaaaaaa...jing ping"
    May 2007
    Denver, CO
    So RUGGED is a zen-master plumber? I'm assuming he learned to sweat before learning to not-sweat. How does all this relate to his PRVs, expansion tanks, and NSF checks?
    Default sweat
    If you start sweating from the bottom and work to the top, the rising heat will help preheat the next joint, but if you work from the top down, the excess heat may loosen the joints you have already done.
