Results 1 to 2 of 2
Thread: muriatic acid and septic system
    DIY Member dirtmover's Avatar
    Feb 2007
    Ontario
    Default muriatic acid and septic system
    Is it OK to use muriatic acid to clean toilet a bowls jets that is discharging into a septic system?
    Apr 2007
    Ontario, Canada
    No do not use muriatic acid if you are on a septic tank. The acid will kill the bacteria in the tank.
    Muriatic acid should NEVER be poured down a storm drain, a sink or flushed down a toilet. It can cause extreme damage to pipes, dissolve solder and damage the biological balance of your septic system.
