Results 1 to 8 of 8
Thread: Funky Sink Trap Problem
    DIY Senior Member molo's Avatar
    Sep 2006
    cold new york
    Default Funky Sink Trap Problem
    New sink - Stem drain moved
    Look at the pics and you will see that the new sink drain doesn't come down into the trap.
    1. What is the best way to fix/move this?
    2. Also, how do I get the nut off the trap in the upclose photo? It just kept spinning....
    TIA,
    Molo
    "Any American who is prepared to run for President should automatically, by definition, be disqualified from ever doing so."
    Gore Vidal.
    Dec 2006
    Um... it's called an offset, basically two elbows to get the pipe to where you need it.
    You have a bigger problem, which is that this is an S-trap, as opposed to a P-trap, and that needs to be adressed (do a search of this forum for more info, I'm not sure where to start).
    That nut looks loose, already. Did you try pulling up on the pipe?
    Sep 2006
    cold new york
    Perhaps now is when I learn what to do with an S-trap. This is original plumbing. The current trap system goes into a galvanized pipe at the bottom of the cabinet (in photo). Do I need to rebuild the trap system?
    TIA,
    Molo
    Gore Vidal.
    If you've loosened that nut, you should be able to pull off the trap. Then the nut should just slide off, unless that S pipe is flanged, in which case, the nut must come off at the other end.
    Plumber BAPlumber's Avatar
    Jul 2007
    Vashon, Washington
    one way to solve this would be to rebuild with a mechanical vent (air admitance valve, AAV), although it may not be legal in your area.
    here's one way. from bottom to top, remove the chrome riser and nut, install 1.5" galvanized coupler, PVC male adapter, pvc pipe, santee with AAV at least 6" above. the horizontal part of the santee is then used for a conventional P-trap with pvc trap adapter. This pvc riser can easily be oriented to recieve the sinks tailpiece and P-trap.
    Brent
    Sep 2006
    cold new york
    Gore Vidal.
    Jul 2007
    Vashon, Washington
    That type of set-up would work, but I would use a sanitary tee in place of the long sweep combo fitting.
    Brent
    Default why a San Tee, explained.
    that picture in that thread was later improved on. Scroll down that thread.
    to make it clear,
    - a Sanitary Tee is needed. It makes the horizontal piece coming out of the P trap connect just right to the vented "stack" (vertical drain pipe)
    - using a Wye and a 1/8th bend, or a Combo (Wye and 45 degree), is not good because waste water begins dropping down and gaining speed before venting. Before water starts falling, gaining speed and sucking air behind it as it advances, vents are required. Venting needs to be connected / applied / made available / before the drop.
    david
