Thread: A simple question
    Default A simple question
    I've been reading the threads posted here and I tell you just from what I've read, I have been able to solve all of my problems but one.
    What side of the pump does the psi gage go. Intake or out?
    Please advice,
    Rob
    scratch-pad engineer and mechanical fabricator leejosepho's Avatar
    Nov 2006
    The pressure switch and guage usually go between the pump output and the pressure tank, and usually closer to the tank than the pump.
    If the suction side of the pump had any guage at all, it would be for vacuum rather than pressure.
    Default Question
    Hello,
    The output or pressure side of the pump is where the gauge should be located.
    Kingfisher
    Default Thank you
    Thanks guys. You've been a great help. My project has come to a close. The gauge is set to 40 PSI to turn the system off and a differential of 20 PSI to turn it on. All systems are a go.
    Thanks for the forum and thanks for your help.
    Rob
