Verdeboy
- Messages
- 2,041
- Reaction score
- 6
- Points
- 0
I pulled a toilet to install a new tile floor and the flange is sort of borderline. It has one of those red outer rings that apparently was never anchored into the cement floor, since it still spins freely. The inside part of the flange is fine, but this red ring is very corroded and the bolts will probably pull out eventually (if not this time).
Is the best way to repair this to cut out this outer ring and replace it with the same? If I do that, I'll have to cut the new ring in half to get it to fit under the lip of the inner part of the flange. Or should I leave it alone and try using a couple of those "spanner flange" repair kits?
Do they sell that red ring where it is hinged, so you don't have to cut it in half?
