Page 3 of 3 FirstFirst 123
Results 31 to 40 of 40
Thread: Stuck Moen Cartridge
  1. #31
    DIY Member DavidSeon's Avatar
    Jul 2012
    MS Gulf Coast
    Default Moentrol Cartridge Removal
    Moderator, feel free to delete this post. My question was covered in an existing thread. I usually do a search before posting, got lazy this time.
    Installing a Moen 3570 valve.
    Name:  Moen 3570 TubShower Valve.jpg
    I seem to remember from somewhere that you should remove internal parts from a tub/shower valve before putting a torch to it, but I can't figure out how the cartridge comes out. Is there an alternative to trying to find the Moen 104421 special tool?
    Name:  Moen 104421 Cartridge Removal Tool.jpg
    It looks different from my other special tool
    Last edited by DavidSeon; 10-12-2012 at 01:17 PM. Reason: Subject Already Covered In Existing Thread
    Old Retired Computer Programmer
    Obsolete and loving it
  2. #32
    The valve in your picture has such a large "thermal mass" that you would not have to disassemble it to solder the pipes in, if you apply the heat properly.
  3. #33
    There is a clip at the front of the valve that pulls out from the top. Then the cartridge can be pulled out.
  4. #34
    Jul 2012
    MS Gulf Coast
    Got it. Just wasn't sure if I should give it a good tug or not. Thanks for the help.
    Dave
  5. #35
    DIY Junior Member kilm's Avatar
    Jan 2013
    California
Size:  36.1 KBI have a similar problem, any plumber help is much appreciated.
    my shower/tub handle broke while turning it. when i unscrewed everything, i see the cartridge white plastic eaten up and the post i believe its called ( the round metal brass bolt in the center ) of the stem broken in the handle.
    so a removal tool was useless, i got a free replacement cartridge moen 1222 from homedepot, no way to tell my model, except i checked all shower/tub handles on moen website and it seems they all use 1222. the 1222 still doesnt look like my cartridge, mine has very white plastic, the house was built around 2000.
    anyway i drilled 2 1/8" hole in the plastic and put in the holes self drilling screws, tried to twist the screws with a nut wrench and the screws bent and the cartridge didn't move at all, and the plastic broke, i can now see the metal and one round rubber came out.
    i tried using a 1/4" self drilling screw in one of the holes but it was too close to the pipe so i stopped.
    i have used vinegar. nothing.
    now that the plastic broke a bit i can see the post (the round metal brass bolt in the center) which is about 1cm long, i tried to pull it with pliers, and couldnt cause i cant reach deep enought to have a good grasp.
    I called a plumber mr rooter he wanted around $1000 to fix that along with 2 dripping faucets.
    I cant afford that. he told me they overcharge because i called the company directly, he said i could find a self employed plumber to do it for $300, but i dont wana call someone from google.
    im gona buy the lasco 13-2125 removal tool from amazon if i ever get the stem out.
    now im thinking to drill the the round metal brass bolt in the center and use a tap and 1/4" bolt.
    im just affraid that the metal dust and shreds will contaminate the water.
    i had also water leak from the cartridge to the inside wall and into the living room downstairs the first day, until i realized after 24 hours and fixed it with tape.
    it was bad, and i am now afraid of mold or termites. especially that water leaked before when i was cleaning the toilet few months back, i dont know how water leaked to living room, apparently from the floor to behind the baseboard. they make these houses in cardboard boxes ?!
    do i have to tear down the dry wall to check for mold ? i have a newborn in the house and read that it can be dangerous.
    around the pipe is black tape to avoid leaking inside wall.
    thank you.
  6. #36
    If the wetting was a one-time thing, and not long in duration, AND it dried out, mold isn't likely a big issue. It can be if it is wet for a long time. No experience with trying to remove a Moen cartridge, so can't help. If worse comes to worse, and you have access from the rear so you don't have to tear up the tile, it might be simpler to just cut the old valve out and put in a new one.
  7. #37
    DIY Junior Member Yacko Warner's Avatar
    Mar 2013
    California
    Default Bolt Extractor
    My efforts got the stem/core out, leaving the cartridge body behind.
    I used a screw/bolt extractor tool, sized for bolts 5/8 - 7/8", itself 1/2" at the stem. It went in with a half-dozen hammer taps, and I was able to twist it out with vice-grips. It took me maybe two minutes; the tool was $10.
  8. #38
    DIY Junior Member Asiangem's Avatar
    Sep 2011
    Venice Beach
    Default I got my 30 years old cartridge removed with Kano Kroil Penetrating oil and CRL
    Quote Originally Posted by Verdeboy View Post
    Try spraying it with PB Blaster (available at the autoparts store). Wait a while, then try again.
    I had the same problem with a Grohe cartridge which was never removed (over 30 years). I first put CRL Calicum Lime remover on a rag and covered it with the plastic bag and a rubber band to hold it for one week.
    Then I used my very favorite penetrating oil spray is Kroil Penetrating Spray by Kano. Based on scientific discoveries at Kano Laboratories, Kroil creeps into millionth inch spaces!!
    It really works - there is regular Kroil Penetrating Oil Spray or Kroil Penetrating Oil Spray with Silicone (which may affect the rubber gaskets so you might want to go with the regular spray without silicone). I sprayed is several times through the week and let it just sit there with the penetrating oil on it. And it worked to remove the 30 years old Grohe cartridge that was stuck!
    P.S. You can't buy the Kroil Penetrating oil spray the stores but only on-line. The airplane mechanics swear by this penetrating oil spray!
  9. #39
    Nov 2005
    Central Florida
    She may sound like a shill for Kroil, but I agree it's great stuff. I bought a gallon of it when I first got into aircraft mechanicking, and it's looking like that's a lifetime supply.
  10. #40
    Nothing you people are talking about applies to the 1222 cartridge. A 1/2" rod does NOT work. There are several ways to remove the broken 1222 cartridge, but you have to be careful NOT to damage the brass body. I would suggest calling a "good" plumber, because not all plumbers will know how to safely remove it, and might suggest replacing the valve instead.
  1. Whole house water filter cartridge stuck in housing?
    By Trawg in forum Plumbing Forum Discussion & Blog
    Last Post: 09-21-2010, 12:08 PM
  2. Moen cartridge was stuck, replacement leaks
    By TimboFish in forum Shower & bathtub Forum & Blog
    Last Post: 11-16-2009, 11:46 AM
  3. Urgent - No Water - Moen Cartridge Stuck
    By Somnilocus in forum Shower & bathtub Forum & Blog
    Last Post: 11-15-2009, 10:31 AM
  4. Grohe shower reverse cartridge stuck again
    By Danapointhal in forum Plumbing Forum Discussion & Blog
    Last Post: 06-08-2009, 08:13 AM
  5. Moen cartridge stuck
    By scorpsista in forum Shower & bathtub Forum & Blog
    Last Post: 05-09-2009, 03:31 PM
