Results 1 to 1 of 1
Thread: Venting through a double Wye Tee
    DIY Junior Member shelski's Avatar
    Jul 2007
    Mississauga, Ontario
    Default Venting through a double Wye Tee
    I want to re-route my 3" ABS vertical main stack through a wall in the 2nd story bathroom. I want to use a double wye tee. One 45 to be toilet drain, the other 45 to offset the stack to continue through the roof. The center 3" opening would be capped. [See diagram] This is to avoid cutting a floor joist. Is this a workable solution?
