Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: power generation
    DIY Senior Member molo's Avatar
    Sep 2006
    cold new york
    Default power generation
    "With a windmill coupled to a small electric generator [a rural inhabitant] could bottle up enough current to give him light at night." (Atlanta Constitution article, 1901.)
    Does anyone know if wind power is becoming affordable for residential power production? Does anyone have experience to say it is a good or bad idea?
    Molo
    "Any American who is prepared to run for President should automatically, by definition, be disqualified from ever doing so."
    Gore Vidal.
    Plumber Cass's Avatar
    Nov 2005
    You need to have fairly steady wind and for a certin number of hours a day to make it worth while.
    If ti is a viable thing I would think there would B people in the area doing it, you should be able to research it on line and find you answer.
    Wind generators doent even start producing electricity until the wind is at 8 MPH and reaches peak output at 27 MPH.
    Plumber jimbo's Avatar
    I am sure a google could find you lots of info on generators. The larger expense will be the batteries and inverter. The more power you want to use overnight, the larger the bank of batteries you would need. Then, if you want to use conventional lights and TV's etc. you need an inverter and regulator.
    FOLLOW UP: OH,yeah, google is alive with info on this. Here is just one link:http://store.altenergystore.com/Wind...ial-12V/p3960/
    Just to throw out some round numbers, it looks like a 400 watt generator can be had for a grand. A battery which stores 1KWH runs a couple hundred. ( 1kwh is the power consumed by a 100 watt light bulb burnig for 10 hours.)
    There are other necessary accessories, but this gives you an idea.
    Popular Science had an article in the last year or so about a ready to connect wind generator...supposedly installed for around $10K. One big enough to do justice may need to be high enough to get away from some ground effects and shielding from surrounding trees and other effects. Many places have a height limit in the local codes, so you need to overcome that hurdle first. Also, keep in mind that charging lead-acid batteries produces H2, which needs careful management or the house blows up...it is very difficult to see a hydrogen fire. Sometimes, it is just easier to hook it up to send back into the grid. It either slows your meter or reverses it if you are making excess. You can eliminate the battery bank unless you want it as an emergency backup rather than just a means to reduce your costs. Most if not all utilities have rules imposed on them where they have to buy your excess electricity. The rates may not be great, but it's better than nothing.
    DIY Member Backglass's Avatar
    Jun 2007
    New York
    Speaking of alternative power, anyone have any experience with solar panels for generating electricity?
    Have they reached the point of efficiency where it's worth the initial cost?
    DIY Senior Member CHH's Avatar
    May 2007
    Denver, CO
    As I understand it, so far the PV's still need substantial rebates from utility companies and/or tax credits to be worthwhile in an economic sense. They can be competative for off grid installations where the cost of bringing in a service line is substantial.
    The local utility started offering rebates so I've been browsing costs but not looking at the numbers real hard yet.
    Jun 2007
    New York
    Quote Originally Posted by CHH
    It was THIS THREAD on a pool forum and his 10kv array that got me thinking about it.
    Sep 2006
    cold new york
    Connection to the grid sounds like it may be better than batteries. If you have access.
    Gore Vidal.
    Like an engineer alternety's Avatar
    Apr 2006
    Washington
    Check out home power magazine on the web. http://www.scoraigwind.com/ for classes. otherpower for stuff and forums. These people actually build their own generators and blades.
    You will need a tower of some sort. I believe the windmill should be at least 10' above anything that will interfere with wind and cause turbulence (e.g., trees). Note that trees grow.
    General Contractor, Farmer HandyAndy's Avatar
    Apr 2007
    Haxtun, CO
    http://www.bergey.com/
    lots of information here, and one of the best wind turbines made today in the US. both grid tie and battery inverter types,
    Sep 2006
    cold new york
    Default wood power, no steam
    wood power? what do you pros think of this?
    http://www.hi-z.com/websit13.htm
    Gore Vidal.
    Apr 2006
    Washington
    About all the power levels would accomplish is running an LED flashlight or maybe charging some smallish batteries.
    Not too exciting unless you have some low power application you need to run while using the stove.
    In the Trades Bob NH's Avatar
    Oct 2005
    New Hampshire
    Many areas have rules that require the utility to offer "net-metering" where you pay for the difference between what you produce and what you use. When you have demand exceeding production you draw from the grid; when you have production exceeding demand you "sell" to the grid.
    If you look at your electric bill it will tell you how many kWHr you use. Lets say you use 720 kWHr in a month, or an average power of 1 kW. But wind power generally produces on the order of 25% of the rated power of the machine because of variation of available wind.
    So you would need a 4 kW generator to produce and average of 1 kWHr.
    If that 720 kWHr costs you $1000 per year, you might break even if you could get a 4 kW rated generator installed for $10,000 and you could depreciate it, maintain it, and pay the interest for 10% of the cost.
    I think you would have a hard time achieving those numbers.
    The government (that is all of us, via our taxes) pays 1.5 cents per kWHr subsidy to companies that produce wind power. That is why you see so many wind-farms in places that have wind.
    DIY Senior Member Mike50's Avatar
    Jan 2006
    Southern California
    Default oh by the way......
    We have an enormous windfarm nearby. Tourists are in awe and snap photos along the roadway. They think it's great that, thats how we power our homes
    with wind turbines. WRONG.
    Newsflash: The windfarm company sells it ALL to the grid. WE are stuck with all the windmills which many claim are eyesores. They also kill birds.
    I'd would be OK with the adverse issues if I could take advantage of this power
    but I can't, so I'm not.
    And another thing---for anyone that thinks this is part of some cool green ecologic
    thing. You can think again. The windfarm gets bought and sold to the highest corporate bidder now and then. Truth be known-they are actually almost as bad as the oil companies. They could care less...
    and so it goes......
    Mike
    DIY Senior Member BrianJohn's Avatar
    Jun 2007
    VA
    Some thoughts on batteries,
    You need enough battery to carry you through NO WIND periods, this can lead to a sizable investment, in addition sealed lead acid batteries have a usable life span of 3-5 years depending on number of discharges, depth of discharge and recharging current and times (should you start a recharge and then have a discharge). But wind coupled with solar may be viable, still need the battery, but between old sol and the wind the battery will see less discharges.
