Fix Sewer Smell Coming From Unused Toilet
andreaarden
Several years ago, I stupidly turned off the water in my rarely-used upstairs guest room toilet because it was "running" and I didn't have time to fix it. I didn't know until now that a dry trap would allow sewer gas to pass into the house, which seems to be what has happened.
I want to put the toilet back into working order myself if possible (I think it just needs a new fill valve/flapper kit), but is there anything else that needs to be done to fix the dry trap problem besides just turning the water on?
In case it might be relevant, there's also a shower in that bathroom and another toilet on that floor that haven't been used for a long time, but I don't think there's any sewer gas coming from them. There are other water fixtures on the second floor which are used often, including a bathtub and clothes washer; and all of the water fixtures located on the first floor are used daily.
Thanks in advance for your help,
Andrea
Gary Swart
Yakima, WA
When you fill the toilet with water, that will fill its trap. If you are going to be delayed in getting the fill valve changed, you can fill the toilet bowl (trap) with a bucket of water. That will stop the sewer gas. Other traps can be fill the same way.
andreaarden
Fix for Dry Toilet Trap
Thanks! All my problems should be so easy to fix! :) I have one more question: To help get rid of the smell, is it OK to pour full-strength bleach into the toilet? Or, down a shower drain?
Thanks again,
Andrea
You may not need any bleach if you fill the traps...try that first. Then, try a little bleach...you won't need much. If you have a septic system, it won't like a lot of bleach.
