Results 1 to 9 of 9
Thread: Recomendations for a shower valve?
    DIY Member northman's Avatar
    May 2007
    Washington
    Default Recomendations for a shower valve?
    I am roughing in a new shower, just a basic 3x3 shower that will be primarily guest use. Does anyone have preferences for brand or model to ensure a quality unit? The wife/architect will probably need final authority on the style choice, but if I can steer her towards a couple quality brand/model lines then perhaps everyone ends up happy. Thanks for the help.
    Greg
    Feb 2005
    Talking Delta 1700
    do the delta pressure balanced 1700 faucet
    you really cant go wrong with it...
    Licensed Grump GrumpyPlumber's Avatar
    Jun 2007
    Licensed Grump
    Symmons Temptrol, or Allura, they invented pressure balancing..HA!
    "The biggest regrets we have in life are the chances we never took."
    May 2007
    Washington
    Default what does pressure-balancing do?
    Quote Originally Posted by master plumber mark
    what is a pressure-balanced faucet?
    Greg
    Jun 2007
    Licensed Grump
    Quote Originally Posted by northman
    Greg
    Scenario: You're taking a nice warm shower...sweety flushes da toilet, house has awful pressure and the cold side drops in flow.
    Yer scalded!
    A pressure balancing cartridge automatically cuts the flow on hot or cold to equalize any loss in pressure from either side.
    These are required on any new installations and many remodels. An alternative is a temperature controlled valve that contains similar components, but is a set it once type of thing. The cold water temperatuer changes a lot between summer and winter in most parts of the country...regarless, with a temperature controlled valve, you don't have to adjust it. Nor, do you have to turn it up as you empty the WH...it will maintain the set temperature as long as there is enough hot water; switching to basically all hot at the end as the WH empties.
    I am putting in an outdoor shower, would either of these be suitable to use? I have seen the Temprol on outdoor showers but I suspect they arent designed for it.
    Any suggestions on a shower valve for outdoor showers? Thanks
    pressure balanced would still likely be required, even if used outside. The bigger problem will be flushing the water out so it doesn't freeze in the winter.
    I asked the same question a year back. Got lots of recs for Delta 1700. Went with it. Happy with it. My unit has separate temp and pressure dials, which is nice. Keep the temp knob set how you like it, and then only turn the pressure knob to full each time you take a shower.
    (important note: I'm not a pro)
