Results 1 to 2 of 2
Thread: Pipe diameter
    Default Pipe diameter
    Hi. I am replacing my galvanized water lines with cooper in a two story house with a basement. I have the main coming in at 3/4 and will run the supplies at 1". My question is for the first floor supply lines should I knock them down to 3/4 then branch to 1/2" or should I branch of the 1" with 1/2" to the fixtures? The runs are about 10-15 feet from the main supply. I have about 35 psi. Thanks
    http://www.iapmo.org/common/ROP2004/...eprint/ch6.pdf
    Using the page above,
    Check out chart 6-4 for how much each fixture uses,
    Then using chart 6-5, the low pressure portion, you can add up how many units you will be using and determine pipe sizing for all of your branches and main water line.
