Results 1 to 7 of 7
Thread: Valve Recommendation
    Default Valve Recommendation
    I need to replace the PVC globe valves in my existing water source heat pump installation. When adjusting the water flow rate I get a water turbulence and squealing noise. I have two valves in the system, one needs a 1GPM and the other 3GPM flow rate @50psi. I have tried 'dole' valves without success.
    Any suggestions will be appreciated.
    Default Fyi
    I found gate valves to be the answer.... NO noise and good flow adjustment.
    Plumbing Instructor Plumb or Die's Avatar
    Jan 2007
    Southern BC Canada
    Use a globe valve. Gate valves, like ball valves are best not used for throttling applications, because they wear out.
    I like plumbing. Plumbing's my favorite.
    I was using globe valves..... Toooo noisy
    Nov 2005
    need low noise globe valves too. Wish I could find more info on them, in general, too.
    david
    DIY Senior Member CHH's Avatar
    May 2007
    Denver, CO
    Have you looked into manual balancing valves or differential bypass valves?
    Licensed Grump GrumpyPlumber's Avatar
    Jun 2007
    Licensed Grump
    Circuit setters
    "The biggest regrets we have in life are the chances we never took."
