Results 1 to 6 of 6
Thread: Another ceiling fan problem
    DIY Member rburt5's Avatar
    Jan 2006
    Canton, Ohio
    Default Another ceiling fan problem
    I recently bought a house with a remote control operated ceiling fan. Everything on the remote works fine. However, the fan is also tied into the light switch on the wall. The light switch will only turn the fan (and light) off. It won't turn it back on. Is there a simple wiring mix up, or do I need a different type wall switch?
    Also, if I leave the wall switch in the on position and use the remote control to turn off the fan, it doesn't turn all the way off. It continues to hum and turn the blades very, very slowly.
    DIY Senior Member SteveW's Avatar
    Feb 2005
    Omaha, NE
    Any chance you are using a dimmer switch as your wall switcy? I tried that with a remote-controlled fan and some of the fan's features did not work until I swapped in a standard wall switch.
    Jan 2006
    Canton, Ohio
    It has a standard wall switch. However, the remote control has a dimmer built into it.
    Sounds like the control board may be bad. I'd call the tech support people at the manufacturer to discuss with them.
    Jan 2006
    Canton, Ohio
    I called the technical support people and they said that my model of fan cannot be controlled by the wall switch. He said to hang the remote control beside the light switch. I'm just going to buy a new fan. Thanks for your help.
    Rancher
    Guest
    Quote Originally Posted by rburt5
    Thats a true statement, however that doesn't answer the question on why the remote doesn't turn the fan all the way off. Buy a different brand next time.
    Rancher
