Results 1 to 9 of 9
Thread: Toto Drake elongated or round?
    DIY Junior Member Tail's Avatar
    Aug 2006
    Default Toto Drake elongated or round?
    Thanks so much for this forum. It is really helped in deciding a replacement toilet for a bathroom remodel we are doing in Ohio. From your responses we have decide on a Toto Drake. The question now is whether we should go with the round or elongated? Our bathroom is definitly on the small side with only a 30" width between the walls where the toilet fits in and a depth of 41" to the door. From measurements an elongated Drake will move the outer edge of the bowl out another 2" from the current bowl which is round. The current depth of our toilet is 26". So I was wondering what others thought about comfort and space in regards to the round or elongated bowl shapes?
    Jun 2007
    Licensed Grump
    Looks like your knee's will be almost touching the wall even with a round bowl.
    Where you sit, is the same, regardless as the whether its round or elongated.
    The elongated is 1.5" longer at the very end, but your seat is in the same place.
    Normally you like to see 24" from the end of the bowl, to the next wall.
    Jun 2007
    Licensed Grump
    yep, also 18" side to side from center of the flange.
    Apr 2007
    Ontario, Canada
    Comfort for a guy is better in the elongated as you have more room in the front.
    I think you would better to have more room in front of the bowl if your space is that tight.
    We're in a small bathroom situation too - we have the round model, and it's quite comfortable (and yes, I'm a guy!).
    Plumber Cass's Avatar
    If you have the room and would like to have a happier wife get the elongated.
    Women prefer the elongated over the round.
    I have all elongated toilets. As a guy, larger target. I am in to good function which is why I like toto's. Sounds like a tight space. Good luck.
    DIY Senior Member achutch's Avatar
    Oct 2005
    Vermont
    Default Elongated / Round
    I have 1 elongated (Toto Drake - ADA Model) toilet and 3 round bowls (antiques). The elongated and extra tall Toto wins hands down for comfort. Compared to the Toto, the others feel like I'm sitting over a chamber pot!!
    achutch
