TOTO Neorest 500 toilet product review and comments. MS950CG
9.5" will work.
6" needs to be moved out though.
With the unit on hand, you can get an idea for what can be done without kinking the braided connector.
denverboz
Denver, CO
Hey Terry, great site and great information on the Toto neorest.
Got a quick question about the electrical requirements. Do you know how much power the Neorest uses, and if it requires a dedicated circuit?
I can't seem to find anything about it. TIA for any help.
BTW I can't get the links to the owners manual in this thread to work, don't know if it's me or they're just bad links.
OK I did find this about the Neorest it says: Power Rating 120V 60 Hz 1281W.
But honestly, even after googling it, I'm not sure what that means. I don't think it means it uses 1281W, just not sure. Maybe I'll post in electrical.
Furd
Engineer
Wet side of Washington State
I suspect that it does indeed mean that it requires 1281 watts under some circumstances. That pretty much means a dedicated 15 ampere circuit or a lightly loaded 20 ampere circuit. While it might pass code being on the required 20 ampere bathroom circuit I would feel better about it being on a different circuit.
Stu L.
New York, NY
I currently have an ultramax and an S300 washlet. Would the neorest offer an advantage in washing? It definitely has the edge in the looks department, but when it comes to toilets the proof is in the pudding (no pun intended). Is the motorized flush superior? The Ultramax has been a hell of a toilet, and the washlet handles things pretty well when my poopy is soupy. Maybe the Neorest offers a better blow dry/style? If there are real advantages I would go for it. Thanks.
MS950CG-12
Neorest 500 in Sedonia Beige
Installed 2/28/2014
The water heater install and Toto install went great! Thanks!
Jay
Fred Duggan
Washington
Is there any way for the AC wire to be hidden? I love how it looks, but I hate that it has a power chord coming out of it...
asimo
British Columbia
Is the toto shutoff valve mandatory at all ? I know it has a filter inside . but can you use a sharkbite plex pipe fiting connect from in wall directly to the toilet without using their hose and shutoff valve?
No. You must use the shutoff that comes with the toilet.
The standard shutoffs don't even come close to working.
SamC
Georgia
Just curious. Since the Neorest uses a pump to provide pressure, and needs the large incoming line for sufficient flow, how does the manual flush work when the power is out?
philly john
Philadelphia, Pennsylvania
We got the 500 2 weeks ago, it was an almond color floor model on clearance for $300, a deal we couldn't pass up. After reading through the multiple instruction manuals, testing the water pressure (we have 40 psi), I decided to tackle the install this weekend.
I'm moderately handy, and so far have spent about 8 hours on the installation.
At this point, it's mostly installed with the exception the shutoff valve. Now the the water line is run using a series of connectors that are restricitng volume and inhibiting the unit from flushing properly. I was hoping to get by without breaking out the torch but such is life.
Also, the drilling through the tile is a less than positive experience, after breaking 4 mid-range masonry bits, I took another trip to the depot to buy some bosch carbide drill bits. Really made things easier, something I should have done in the beginning.
I'm going to re-run the water next weekend and will post pictures afterwards.
philly john
Almost forgot, the back wall is concrete so the water line comes up through the floor rather than the wall. I don't think this should be an issue as long as I position it in such a way as to not kink the braided cord, but we'll see.
Through the floor for the supply is fine. You will point the shutoff where you need for the least amount of bend. It does need the full size shutoff and supply that comes with the unit. We've installed so many of these units. You do need to slow down a bit while working on them. There are a lot of wires that need to be left intact.
There is a lever on the right side as you look at it that works the manual flush during a power outage. You don't get the bells and whistles, but it does flush.
philly john
This is the original line for the old unit, initial I was optimistic that the toto could be installed without breaking out the torch
JoyC
NY
Most plumbers are roughing water at 6" to the left.
If you are installing a Neorest 500, the water needs to be moved over.
The Neorest comes with it's own shutoff with filter screen. The large braided hose is needed or it won't flush right.
You can't use a 3/8" hose on these, no tank, so you need more volume.
Hi Terry-
I have the Toto neorest 500 and love it but something got hit on the right side when sitting on the toilet and now it’s been leaking by the water drain lever and washlet shut off filter. I tighten the filter so much that the plastic is shredding. Not sure what the drain lever does. As I didn’t install this not sure what’s going on but it’s been leaking a lot now from that area. Please let me know if you know what’s wrong since you’ve installed a lot of these. Thank you in advance.
