Results 1 to 8 of 8
Thread: HELP PLEASE! What will I need to pull a pump from my well
    Smile HELP PLEASE! What will I need to pull a pump from my well
    I need to pull the pump from my well because of a leak or faulty check valve. What will I need for this or is it best to leave for the Pro's?
    Plumber Cass's Avatar
    It depends on how deep it is. How deep is it?
    116 feet deep
    Previous member
    Jul 2005
    Riverview, Fl.
    Is that where the pump is hanging or is that the well depth?
    bob...
    DIY Senior Member Mr_Pike's Avatar
    Jun 2007
    Nebraska
    You need a way to lift it, and at least 2 large pipe wrenches, a pipe brake to keep it from sliding into the hole, at least 2 large sets of vice grips as safety catches, about 3 rolls of black tape, a knife, and a large wrench to slide the pitless guts away from the casing. The pipe sections are 20' tall. Hand lifting a 100+ footer is going to be very difficult at best.
    Thanks for the info. I think I will call the well company.
    If it is black polly well pipe I have pulled them out by hand 135' deep.
    It takes 2 guys.
    DIY Senior Member rshackleford's Avatar
    Oct 2005
    Eastern Montana (The Bakken)
    we have a local driller who will set poly pipe as deep as 500 feet. talk about a lot of work to pull this pump!
    rshackleford
