My system is not holding presure. The pump comes on then shuts off at 40 PSI. The presure then drops rapidly to 20 PSI and comes on again to start the cycle all over again. Is this a problem with the tank (Blue) or a check valve? Also can I adjust my water preasure settings with the current switch I have or are the switches rated? Will I need a different one?
