Results 1 to 5 of 5
Thread: Fastening shower neo angle shower doors to fiberglass
    Default Fastening shower neo angle shower doors to fiberglass
    Hello,
    What is the best method to fasten neo-angle shower doors to a fiberglass enclosure? The kit came with simple plastic wall anchors. One time-life book said to use molly bolts. The doors are fairly heavy (1/4" saftey glass) so I want it secure. Also, the instructions say to drill and screw the curb piece directly onto the fiberglass pan. That seems like I'm just asking for a leak under the unit.
    Any thoughts/ideas would be appreciated.
    Plumber, Contractor, Attorney LonnythePlumber's Avatar
    Wichita, Kansas
    Default Neo Challenges
    I have not had a problem with the plastic anchors when I have had to use them. It is better to have blocking behind the fiberglass or if you had a stud back there you could use 3" screws.
    I have not heard of drilling into the pan to secure the glass framing and I am curious what brand you have that advises this. It is hard to set neo angle walls and keep them from leaking. It is very important to have the pan level and preferably square with the walls.
    Default shower door
    The top frame gives the door and walls the necessary rigidity, so the anchors are basically just keeping it from shifting against the wall.
    Default Neo Install
    It's a Cardinal CD Neo. The Cardinal web page instructions do not mention drilling into the pan. The local distributor have slightly amended instructions that do include a step for drilling into the pan. With the 1/4" glass doors do you think I can skip that step?
    By blocking do you mean a piece of wood of any particular length? If I can gain access behind the enclosure, would a galvanized bolt, nut, and washer assembly work?
    I've got it square and level, it's replacing an inexpensive neo-angle unit that got cracked by a very heavy bottle of shampoo dropped by my wife.
    Wichita, Kansas
    Default No Drill
    I would not drill into the pan, blocking sufficient to cover all three or four holes from the frame and brass or stainless steel is better than galvanized.
