Results 1 to 8 of 8
Thread: I need a 1 1/4" slip joint 90 degree elbow.
    Default I need a 1 1/4" slip joint 90 degree elbow.
    Anyone know where I can find one? They are tough to find on the web and Home Depot didn't have them. Thanks
    I assumed you are looking for PVC, but regardless of whether it's copper or PVC, go a a real plumbing shop. Box stores typically only handle items that have a fairly rapid turn over. Most plumbing supply houses say the will only sell to licensed plumbers, but for one or two pieces they usually will make a cash sale to anyone. Just don't expect to buy major items.
    Plumber Winslow's Avatar
    Dec 2005
    Hawaii
    sounds like he's looking for a slip joint 90.The one used for tubular brass.
    Apr 2007
    Ontario, Canada
    This company has 1-1/2 or 1-1/4"
    http://www.************.com/invt/u238413
    don't know why but the name of the company above is "do it yourself" don't know why it shows up as ***
    Plumbing Contractor srdenny's Avatar
    SF Peninsula
    They are offering an 1-1/2" tee with 1-1/2x1-1/4 bushing washers.
    Default elbow
    A double slip joint elbow is a difficult fitting to keep together. What you need is a 1 1/4" "flush elbow" which has a slip joint on one end and a length of tubing on the other that you cut to fit as necessary. Good plumbing stores have them.
    I assume this is for a bath faucet. Many times it's easiest to go from 1 1/4" to 1 1/2" at the pop-up drain using a reducing ferrule. Then use a 1 1/2" p-trap, etc..
