Results 1 to 5 of 5
Thread: Help identifying a shower valve (and color)
    Default Help identifying a shower valve (and color)
    Anyone seen this before? I need a brand and color. My customer just wants the trim replaced. Also the name of the trim color for the shower door.
    Picture here:
    www.californiabathliners.com/whatisthis
    Default valve
    Price Pfister Avante antique brass. The octagon plate is still available at some sites but not in antique brass. Chrome and polished brass may be the only options.
    Apr 2007
    Ontario, Canada
    I think your customer should replace her grout or at least clean it.. geez
    Thanks for helping me ID the fixture. I won the replacement parts on **** today for $0.99+17.00 s/h.
    The entire (65"x 40")tiled floor and walls are getting a liner system to cover it all up.
    Don't know what you mean by a "liner" but adding wall thickness will possilby cause the handle and trim not to fit!
    If it is a glue-on wall kit, the manufacturers that I am familiar with recommend NOT installing over existing tile. I believe it is related to not getting proper set of the glue on a non-porous surface.
    Anyway, whatever you do , read the specs and instructions that come with it.
