Due to a construction project I needed to move my lawn irrigation pump. I first sand sucked 19 feet with PVC and hit clay. There was 8 feet of water in the casing. I opted to pull the PVC and drive steal pipe through the clay in hopes of reaching more water.
I drove 25 feet of 2 inch and have a 3 foot 2 inch point. I have 14 feet of water in the pipe. I attempted to prime a 2.5hp pump every which way including hooking up a garden hose to the intake on the pump side of the checkvalve. I have filled the supply line with water and it holds to the check valve. I bought a replacement pump to try and determine the issue, it also will not prime.
I have been told that 28 feet is too much for a regular pump to pull water. Is that true and what options do I have if that is the case. I am reading up on jet pumps, but will that option work with only a 2 inch casing?
Thanks Much in Advance
