Speedbump
Active Member
The items in the control box either work or they don't. They don't act intermittantly. What makes you think the pump isn't running when the switch points close?
bob...
bob...
Controller? Is this a 3 wire pump? When the switch clicks on at 40, does the pump start?millsrj said:Will draining the system and putting 38lbs of air in the tank solve this problem, or could it be the controller?
the pump is only 2 feet away, I can feel the vibration when it kicks on.
I have a submersable pump down at the lake that feeds my outdoor watering needs.
I think you said this is a three wire pump. If so, you need one more wire. And from the pump to the controller, the wire colors should be black, yellow, red and green (four wires not three). Are you sure it isn't a two wire pump and the controller is something other than a control box?From the pump - to the controller: bl/wh/ground
from the Pressure switch to the controller: bl/wh/ground
from the pressure switch to the breaker: bl/wh/ground
