I have a pressure switch that was set 40/60. Recently I noticed the pump was running for a long time each cycle. I just watched the pressure gauge and the pump now doesn't cut on till 30 psi and then it runs up to 50 psi fairly quickly but then continues to run and run and run till the pressure is 55psi.
I have a captive air tank also on this system set to 40 psi .
Patra
Patra
